Mortscript is required, and you need Mode of Operation in your Registry.
The CAB should install it, but just in case it's located:
HKLM/Software/OEM/PhoneSetting
HiddenModeOperation should be 0.
If you're having problems, make sure Mode of Operation is the EIGHTH option in your settings, it should be, but just make sure.
If you're not familiar with it, check it out. If you do a lot of texting, switching from EVDO to 1X can drain the battery INCREDIBLY quickly, using this script is an almost instantaneous way to switch between them.
Leaving the phone in 1X is proven to increase battery life, VERY drastically if you're a heavy texter. Just switch to EVDO whenever you need data, then switch back.
Check it out, make sure it works.
Chefs, feel free to cook it in.
(Note: MSCR file is placed in /Program Files/intx/Toggle1X/, Shortcut placed in Programs).
Thanks,
intx
originally found here:
http://forum.ppcgeeks.com/showthread.php?t=86819
