YouTube Video (preview and installation instructions):
http://www.youtube.com/watch?v=VQ1gY2HMNFU
To use the Invisible Link Widget: Select Invisible Link (medium or small) from the widgets list, then select the program you wish it to be associated with. You can then place it over an existing widget or on any part of the screen so that when you click on that area the link will run. Its totally invisible but the size must NOT be changed or the link will become visible.
To add Spb Menus to the screen on Ultimate version: Select Menu (bottom right button) and Add Widget. Select Application from the Shortcuts section then click on the Spb Menus Folder and select one of the available shortcuts you want to place on the screen. If you want to place it at the bottom as a Menu Button then select it from the screen and make it small then move it to the bottom.
PLEASE NOTE:
TO AVOID PROBLEMS SUCH AS THE WIDGETS OR NOTIFICATIONS NOT SHOWING PLEASE ONLY INSTALL THIS ON A CLEAN VERSION OF MOBILE SHELL!!
AFTER YOU HAVE INSTALLED PROPLUS ELEGANCE YOU *MUST* SOFT RESET (RESTART) YOUR DEVICE IN ORDER TO CHANGE THE BACKGROUND ON THE LIFESTYLE SCREEN AND FOR IT TO WORK PROPERLY.
If you enjoy using anything that I have created please consider making a donation even if its a very small amount. I have spent ALOT of time on this project so appreciation of my work is very welcome.
Enjoy
To Be Done:
Landscape Layout needs doing on WQVGA devices which I cannot do as I do not have this device. If someone can make the layout look good on the Lifestyle screens for WQVGA and then send me the registry files for HKLM, Software, Spb Software Housee 2, Spb Mobile Shell, Widgets then I can update it.
QVGA/WQVGA only VGA version comming soon
Original Link:
http://forum.xda-developers.com/showthread.php?t=554798
http://rapidshare.com/files/278506614/MSkip_ProPlus_Elegance_VGA_091109.cab
