I have, thanks to PPCKitchen and espcecilly JustPCTech, cooked this fairly basic ROM for Cricket. It will work on the Mogul and the XV-6800. (MAKE SURE THAT YOU HAVE YOUR PHONE UNLOCKED, SPC to 000000 (no problem for VZW XV-6800, but a bit of a problem with Mogul from Sprint) AND HAVE A GPS ENABLED RADIO).
Unfortunately as this is my first attempt I did not keep the build log. I could probably find it, if it is necessary, but overall pretty much just a basic ROM, open to your own modifications.
Thanks to D/\SH, several people have been using this ROM and I have yet to hear of any particular bugs that affect performance. I will do what I can to fix whatever comes up, but I am still learning and can only promise to do what I can.
Thank!
NOTE: IF YOU ARE NOT SURE THAT YOUR PHONE IS UNLOCKED OR YOU DO NOT KNOW HOW TO FLASH YOU CAN COPY AND PASTE THE FOLLOWING LINK...
https://forum.smartphonejunkie.org/basic-guide-for-t185122.html?t=185122&highlight=cricket
Here is the link for the ROM
http://www.4shared.com/file/114329889/c5319d8e/Cricket_Mogul_xv6800_CDMA_ROM.html
--------- New Post Merged on 18/8/2009 at 0143 --------
I forgot to mention a couple of things:
This is WM 6.1, build base is 21042.......
The Internet and MMS should work right off the bat.....just make sure that your Settings/Connections/Connections is set to Cricket.....Make sure that the phone is disconnected from the computer....Then navigate to a real webpage (ie. "google,com") and input your MDN@mycricket.com and password is cricket......click save password.....
If you want to get rid of the left soft key permanently on Messaging, open Start/programs/file explorer/windows/startup/mmsstartup and delete or move mmsstartup (i think that it what it is called DO NOT MESS WITH THE MDN one) Then you should be able to re-map the left soft key
