RequirementsWM5/WM6/WM2003
Overview2Easy Lock protects your touchscreen from accidental touches.
2Easy Lock protects your touchscreen from accidental touches. 2Easy Lock is fast to unlock.
· Securely locks touchscreen.
· Quick and easy to unlock - simply slide the button to the bottom of the screen.
· If you select “Keep Protecting†then rest easy when your screen goes off - 2Easy Lock will automatically protect you when your screen comes back on.
Minimum Requirements:
· Some devices may require installation of the .NET Compact Framework 3.5, available for FREE DOWNLOAD here:
http://www.google.com.au/search?q=microsoft+.net+compact+framework+3.5+download&ie=utf-8&oe=utf-8&aq=t
· 240 x 240, 240 x 320, 240 x 400, 320 x 240, 320 x 320, 400 x 240, 480 x 480, 480 x 640, 480 x 800, 640 x 480, 800 x 480
Info
http://www.mobihand.com/product.asp?id=31642&n=2Easy-Lock
Install & Use the included keygen to generate your registration key.
http://rapidshare.com/files/261625087/Peter.Brownlow.2Easy.Lock.v1.0.XScale.WM2003.WM5.WM6.Incl.Keygen-SyMPDA.rar
[DOWNLOAD]http://www.megaupload.com/?d=2TKQ666D[/DOWNLOAD]
[DOWNLOAD]http://depositfiles.com/files/3fqr206yn[/DOWNLOAD]
Keygen Only:
[DOWNLOAD]http://rapidshare.com/files/261626478/Peter.Brownlow.2Easy.Lock.v1.0.Keygen.rar[/DOWNLOAD]
[DOWNLOAD]http://www.megaupload.com/?d=3XY1GSMT[/DOWNLOAD]
