Got chaos in Outlook? TrineFix can help! :)
TrineFix is a free utillity for contacts, appointments and tasks on yourWindows Phone (and if you sync with a PC or ExchangeServer, also on your PC).
Update TrineFix 2.1
Info/Code:http://www.trineseries.com/TF.aspx
TrineFix 2.1 08.01.2009
* Enhancement: "Fuzzy-logic" for country code fix (numbers WITH existing country code that has no seperator characters will now be reformatted in most cases, was always skipped in earlier versions)
* Enhancement: Info about new version is enhanced (will automatically show in MainMenu, even when MainMenu is drawn before reply from TrineSeries.com
DISCLAIMER: As always, it is good advice to back up your PIM or whatever you are installing :)
Main features:
* Remove "close match "duplicate contacts (and You decide what fields must be similar to define it as a "duplicate")
* Option to automatically remove any "exact match" duplicates (if their identical, you only need one, right!?:-)
* Set FileAs for contacts ("Firstname Lastname", or "Lastname, Firstname", and so forth)
* Add a default CountryCode-prefixes for phonenumbers that do not have a countrycode
* Change the countrycode-formatting ("001", "+1", so forth) for all phonenumbers
* Remove duplicate appointments
* Bulk remove several appointments, contacts or task with a searchword
* Preview fixes before applying, and you can even manually adjust the fixes before applying in most cases
* Fingerfriendly user interface (if you have a touchscreen)
* Keyboardfriendly user interface (is you have a keypad)
* Adjusts itself automatically to different types of devices (touchscreen/non-touchscreen) and screentypes (QVGA, VGA, WVGA, square screens, ...).
* Built in functionality that notifies you about new releases of TrineFix, and makes it possible to upgrade easily directly from your phone
* Share with friends (send SMS with download links to a friend)
TIP!
Another very usefull (and free) application, that you can use to take backup and restoring all your contacts, appointments, sms's, E-mails and so forth called PIM Backup (has nothing to do with us, we just like it ourselves:-). You can find it here:
http://www.dotfred.net/
This program should work with all Windows Mobile devices, that has WM2003 or later (has been tested on Smartphones, Professional Edition, QVGA, VGA, WVGA, 320x320). The program requires that "Microsoft .Net 3.5", is installed on the device.
Installation
If you want to try it out, just click here for installation instructions, and links to installation files (including .Net 3.5 installation, if you don't have it already).
Known bugs
There is no known bugs in this version.
Comments/feedback
If you have ANY kind of feedback, we have our own thread at the excellent xda-developers forum.
There you can tell us what you like, or dislike. And if you miss something from TrineFix, mention it...maybe we will add it. Can't promise anything...but we try to listen
