PHASE II COMPLETE
PHASE III IN PROGRESS (AGPS FIX FOR VZW TP)
UPDATED 12/25/08
Please read completely. I really don't want to have posts asking about things stated in this post.
First and foremost.... This fix is to be still considered beta at the present time. I WILL NOT be held responsible for any damage to your device or any charges from you carrier if you happen to be in roaming because of this.
Phase II is finally here and I know I've been asked many times on what Phase II meant. Well I now have that answer. The newest release is Verizon PRI 1.46.002 coded to allow full programming updates :) , full PRL updates :) NO banner issues :) and last but not least .... :D.... oh ya ....:D GPS .... "takes a bow on this one"
Hope that answers the questions I kinda reframed from answering.
Here we go again
UPDATED 6/08/09
Verizon has unlocked the GPS as of 6/08/09
Attached is PPST2.01.cab Please use that file as a replacement for lllboredlll_VZW_GPS_Fix_v2.cab
This will make it possible to still unlock the GPS without flashing the full updated ROM
1. download lllboredlll_VZW_GPS_Fix_v2.cab your storage card or any folder
2. NOW install lllboredlll_VZW_GPS_Fix_v2.cab
3. use gsfinder,total commander or File Explorer to navigate to \windows\ppst.exe (EVERYONE MUST COMPLETE THIS STEP FOR THE FIX TO TAKE AFFECT)
4. reset your device as needed
5. Dial *228 option 1
(the above step is the steps I did, option 2 also works but I needed to prove it takes a full update without rewriting data)
16. reset your device
7. Install HTC GPS Tool if needed
8. I would suggest a soft reset... do what you want on this one
9. Open up HTC GPS Tool. Set Chip to Q 7500 and mode to Cold Start (left soft key for those who dont know) then set baud to 4800 and open port.
There will be a registry entry made from this install with the GC's AGPS Values for future use or others testing use. Please understand that my device is not capable of AGPS for some reason. When it's figured out the "GPS Fix" will be updated.
Also make sure that your device settings are right.
Settings >> SYSTEM >> External GPS
Programs Tab- GPS Program Port: Com4
Hardware Tab- GPS Hardware Port: None, Baud Rate: 4800
Access Tab- Checkmark on "Manage GPS automatically"
Make sure you turn your location on thru your phone settings. Some ROM's do not have it enabled by default.
If you are having signal problems where you can't program your device after applying the fix. You can try to manually update your PRL to hopefully achieve a better signal so you can program.
Download the 51143.zip from below. Unzip and place onto your storage card or folder on your device.
##775 and send or ##775# depending on your ROM
000000 is the code
Edit PRL - Browse device (should be where ever you put it)
Apply, and the phone will reset.
TO RESTORE YOUR DEVICE DOWNLOAD PPST1.46.CAB
INSTALL
RUN PPST.EXE
REPROGRAM *228
If you are in need of QuickGPS, please view page 60 post 598. Also if you are using the Stock VZW ROM you will need to install the sdkcerts first. Custom ROM do not need the certificates due to them already being implimented into the ROM.
http://forum.ppcgeeks.com/showpost.p...&postcount=598
If you take my research and improve on it all I ask is that you atleast give me credit for the discovery. I've spent a ton of hours working with NV files and PRI's.
Hope everyone enjoys..... :D
original thread can be found here:
http://forum.ppcgeeks.com/showthread.php?t=49933
