Da_G has been gracious enough to consider this the "CDMA Version" of his very popular kitchen. Without his help over the past two weeks, I would have never been able to get the new Bepe (Ervius) style kitchen working. I also received a lot of initial help from MightyMike. His kitchens and personal OEMs are what got me started. So, here are the usual "thank you's":
Da_G (XDA), MightyMike, Bepe (XDA), Ervius (XDA), Dan-HTC-Touch, Tsowen (XDA), Showaco (XDA), TPlane37 (XDA), Calkulin (XDA)
If I have forgotten to mention you in the above list, don't worry, I didn't forget about you. (Wait, yes I did.) But, please send me a message so I can add you to the list!
This IS NOT my first relase of this kitchen/ROM. This is simply my first release of it on PPCGeeks. You can check the history of dB_ROM at my XDA Thread. Read through the posts there, you will see it's one of the best around. I finally posted this here because the GSM Raphael rules XDA. I was the first to launch a CDMA Kitchen for it there. That shows you how few people actually talk about the CDMA TP there. So, I would like to maintain both threads. Please help me in doing so. Thanks!
Information on where the Kitchen was built from:
SYS: Da_G
XIP: Da_G
OEMs: MightyMike, Da_G, Tsowen (Taskbar), Showaco (Titanium Weather), Me
EXTs: Same as OEMs list
Kitchen Design: Da_G modification of Ervius' base kitchen based on Bepe's new style kitchen (PlatformBuilder)
CHANGELOG:
Wednesday (5-6-2009)
Updated SYS to 21222
Added ATContacts
Added CHome Editor
Updated Titanium Weather to 4.2
Updated Mortscript to 4.3b5
Added Option for 4 Column Start Menu in Kitchen (Included in ROMs)
Minor Registry Tweaks
Monday (4-5-2009)
Updated SYS to 21502
Updated to Ervius 7.6
Changed Organization of EXT Folder per this update
Fixed multiple build errors that were being suppressed
More accurately diagnosed and corrected "Corrupted Ringtone" errors
This should fix the silencing of sounds/notifies randomly
Were some memory overlaps in a key module
Fixed Teeter
Minor Registry Tweaks here and there
Added many different "pre-built" roms.
Each of these have a ".erv" file. Look in "Load ROM"
Look below the screenshots for the Comparison Table
Monday (5-11-2009)
Updated AdobeFlashLite
Updated RemoteDesktop
Updated Widgets
Updated Windows Update
Titanium Pictures tab open HTC Album by default (if Album installed)
Added Notification Enhancement (Rhodium/Topaz)
Added Custom Round Icons for NE
Added New Round Taskbar Icons
Added PowerOff Warning to match NE
Added White NonS2A Dialpad Skin to Kitchen (No ROMS built with it)
Updated GoogleMaps to 3.0.1.6
Updated HTC Zip to 1.21.18193225.0
Added G-Alarm 1.5.1
Added SmartLock 1.7C by Chobit Company
Resolved XIP Issue for VZW TouchPro's
Dropped SPRINT FULL from Pre-built ROMs
Dropped ALL CDMA Carriers Basic from Pre-built ROMs
Added SprintTV and Sprint NAV to CABs (Still in Kitchen)
Added ATContacts
Added CHome Editor
Monday (4-5-2009)
Fixed Teeter
Stable enough for every day use? Well, I am (Yes, I stole this from Da_G, BUT, I REALLY AM USING IT DAILY!)
Instructions for new style kitchen (build 21501 and above)
Step 1. Extract to a clean folder
Step 2. Run erviuskitchen.exe
Step 3. Click "load rom"
Step 4. Choose "dB_ROM-21501"
Step 5. Scroll down to section labelled "HERMAN-Device: HERMAN_External_Packages" in blue text
Step 6. Double click packages here to enable or disable them (first column reads True for enabled, False for disabled) (Leave alone for Defaults)
Step 7. Do the same for section under that labelled "SHARED-Devices: WindowsPhone_Components" as step 6 (Leave alone for Defaults)
Step 8. (Optional) Click "Save ROM" and choose a filename, to save your package choices for loading in the future
Step 9. Click "Create ROM"
Step 10. ROM is available in .nbh form in kitchen folder \HERMAN_RELEASE, you can either flash it with the included RUU.exe or rename to RAPHIMG.NBH and place on fat32 formatted SD card, for SD flash
General Notes for ROM and Kitchen
Always hard reset after initial flash. (I always wait till Autorun/SDAutorun complete and device soft resets)
Soft reset after hard reset doesn't hurt anything. (Comes from my old Titan days)
Don't worry about all the "Overwriting..." in the kitchen build process. It's normal and expected.
DO NOT use XIP 21502 in Kitchen. It's broken. I know what it is, but there is no change from the 21501 XIP, so just use it.
Report all bugs, etc here. Da_G and I have worked hard to make this as bug free as possible, but, Stuff happens.
If you are run Windows Vista or 7 and use the Kitchen, you must Right-Click ErviusKitchen.exe and select "Run as Administrator..."
Don't blame me if you brick your device. It's not my, or the kitchens, fault. You recognize the potential problems that can arise from flashing your own ROMs on your phone. Da_G and I will take no responsibility. "Use at your own risk."
All that being said, I have had no issues during flash processes. I use this as my daily phone and have no ill side effects.
Before you Begin
If you have never flashed a ROM before, PLEASE read the information posted by jakdillard in the sticky thread of this forum. You must first unlock your SPL and learn how to flash. All the information on doing this has been gathered and placed in a easy to follow step-by-step guide in the thread. Here is the direct link.
Download Links
21222 VGA WWE ROM - Full - Sprint Optimized - Beta 1
21222 VGA WWE ROM - Full - ALL CDMA Carriers - Beta 1
21222 VGA WWE ROM - No Manila - ALL CDMA Carriers - Beta 1
21222 VGA WWE ROM - Basic - ALL CDMA Carriers - Beta 1
21222 VGA WWE ROM - BareBones - ALL CDMA Carriers - Beta 1
21222 VGA WWE Kitchen for Touch Pro (CDMA) - Beta 1
21502 VGA WWE ROM - Full - Sprint Optimized - Beta 1
21502 VGA WWE ROM - Full - ALL CDMA Carriers - Beta 1
21502 VGA WWE ROM - No Manila - ALL CDMA Carriers - Beta 1
21502 VGA WWE ROM - Basic - All CDMA Carriers - Beta 1
21502 VGA WWE ROM - BareBones - ALL CDMA Carriers - Beta 1
21502 VGA WWE Kitchen for Touch Pro (CDMA) - Beta 1
21501 VGA WWE ROM for Sprint TP - Beta 1
21501 VGA WWE Kitchen for Touch Pro (CDMA) - Beta 1
NEW 11/05/09
http://rapidshare.com/files/231819913/dB_ROM-wm6.5_21222-Full-ALL_CDMA_Carriers-v2.rar
http://forum.ppcgeeks.com/showthread.php?t=67426
