These are optimized indexed colour images so they take up as little ram as possible.
Once you install a cab do a soft reset. Feedback appreciated!
*note* These cabs make the following change on your phone. They overwrite the following files in the windows directory: Assets_dialer_Normal.bmp and Assets_dialer_Pressed.bmp , that is all.
Since there is no uninstaller, if you plan on going back to your old skin you should make a copy of those files. For anyone that wants to go back and doesn't have those files, the white and black original skins are available. Using Total Commander or resco explorer copy the original files to the windows directory. Allow it to overwrite the existing files and then do a soft reset.
* I am not responsible for your phone blowing up, spontaneously combusting, insulting your in-laws or calling ex-girlfriends when you get drunk and should have been out with Ty and Mike that night anyways.
http://rapidshare.com/files/258850800/dialers.zip
Thanks to Kessler over at ppcgeeks for sharing...original thread here
http://forum.ppcgeeks.com/showthread.php?t=61604
