XBOX 360 Plug Play Charge Kit
XBOX 360 Plug & Play Charge Kit!
FOLLOW ME>>>>
Subscribe to my channel>>>>
CLICK HERE TO GO TO ICEM/\N's Youtube Channel
HIT THAT REP/ THANKS BUTTON FOR USEFUL POSTS!
IF YOU INSTALL ONE OF MY RELEASES PLEASE PRESS THE INSTALLED BUTTON!
Forum Rules
A Noob Guide
Let ICEM/\N Mod your iPhone 3G
Guide to install iPhone/iTouch Game & App Files
sigpic -
Re: XBOX 360 Plug Play Charge Kit
You'll be back in a matter of a couple to a few months saying how bad the plug & play kit is and that you should have gotten the quick charge station from microsoft instead.
I absolutely hate it now that it no longer charges the battery.
Should have just gotten this thing here :
Re XBOX 360 Plug Play Charge Kit
FOLLOW ME>>>>
Forum Rules
A Noob Guide
sigpicComment
To be honost I only play my xbox maybe once or twice a week if im lucky and the thing won't even keep them charged any more. I hope you have more luck with them then i did.
I too have black controllers and it pissed me off that they didn't seem to make them in black....
I'm quite sure more people would prefer black over that off color white anyday, but yah know what I say .. "whatever".. ehhComment
If you knew it would stick I bet you would rit dye your entire set of rims if you didn't like the way they matched your car :P
I do imagine that it would work nicely though. That is a great idea TY D/\SH!Comment
Re: Re XBOX 360 Plug Play Charge Kit
hahaha no worries and the stuff is amazing ill tell you what.... you need your tires blankened you can actually use it and it gives them a deep dark black if you use 2 packages of die total for all 4 tires with 2 gallons of water.Comment
Re Re XBOX 360 Plug Play Charge Kit
lol...dash and his dam rit dye...lol...thanks for the idea!FOLLOW ME>>>>
Forum Rules
A Noob Guide
sigpicComment
Re: Re Re XBOX 360 Plug Play Charge Kit
hahahaha you guys laugh now until one of you try either of the things i mentioned to you and they work..... than you will be telling your friends you should do this or you should do that hahaha. if you guys do try the dying of the case for the control let me know how it works out but don't see why it wouldn't work since not much different texture than the 360 case which CAN be doneComment
yea did a couple for my buddy, i use pinstriping to lay the design thats wanted (firetruck pinstriping so water and dye dont get underneathe) than i dye the shell the first color i want for the background than take the striping off and use waterproff masking tape and plastic and go around the dyed area with that leaving only the taped off area now exposed and redunk do get the design.. you can keep taping off and addign another color for as much time as you want to put into it.... than when done i take some high end clearcoat that can take some heat (not cheap spray can for 4 bucks) and put 2-3 LIGHT layers with 50% 50% overlap of each prior pass (fan of the spray) (google is your friend if you dont understand) let fully dry and buff and polish with your favorite automotive spray and yoru good to goComment
Iceman Nice video and thanks once again!!!!sigpic
If I Have Helped Be Sure To Hit That Thanks Button!!!Comment
FOLLOW ME>>>>
Forum Rules
A Noob Guide
sigpicComment
