Requirements: PPC WM5, WM6 - Net CF v2.0, Internet connection
Overview: Twobile (pronounced Twoh-bul, a mixture of the words â€ÂTwitter†and “Mobileâ€Â) is a new Twitter client for users of Windows Mobile Pocket PCs. Initially a personal project designed to help access various services provided by Twitter, it was released to the public in 2008.
When you first run Twobile, you will be prompted to go to the Settings menu to set your Twitter username and password. Click OK and the main screen will be presented to you. Click on Menu and select Settings. In the General tab, select the various options you would like enabled.
Below is a brief overview of the various options that are available:
* Run at startup
Allows you to run Twobile when your device starts. Please be aware that this may increase the startup time of your device. This is an experimental feature and should be used at your own risk.
* Show Tray Icon
Allows an icon to be displayed at the bottom of the Today screen for quick access. This allows you to run Twobile and minimize the window, but be able to open it back up quickly from the Today screen without having to re-run the program.
* Download profile images
When running Twobile, data usage charges may be incurred as the program utilizes your available Internet connection to download Twitter statuses and user information. Of this data that is downloaded, profile images of users may also be downloaded. To minimize the amount of data usage, it is recommended to leave this option UNCHECKED and profile images will not be downloaded.
* Enable images in public timeline
Because images are cached on your device to minimize data usage, you may not want to have profile images from users in the Twitter Public Timeline cached on your device taking up valuable space. If you wish to have these profile images downloaded when you view statuses in the Public Timeline, check mark this option, otherwise uncheck it.
* Clear Cache
Depending on how much you use Twobile, you may find your device running low on storage space where you’ve installed Twobile. If you have a lot of Twobile avatars cached, click this button to clear the cache and reclaim some of the space they have taken up.
The Account tab houses your Twitter account information. In order for Twobile to access the features of Twitter and for you to be able to add new Tweets to your account, you must provide your Twitter username and password.
Once you’ve completed filling out all the options (and entering your Twitter account information), you can click OK where you will be returned to the “My Info†tab. Press Login to begin the login process and retrieve your current status information from Twitter.
Twobile 1.7.5
What's New in This Release: [ read full changelog
· Added: Temporary navigation aids when viewing a message/tweet to help cycle through all the tweets for devices with/without hardware directional pads.
Bug Fixes:
· Fixed: API to TweetPhoto so tweets appear with links to photos correctly.
· Fixed: Profile URL link now recognizes alternative browsers and prompts whether to open them in those alternative browsers or not.
· Fixed: Recognition of “http://tweetphoto.com/< image-ID >†links as valid TweetPhoto links.
http://www.infinitumsoftware.com/
http://www.uploadjockey.com/download/hpcponq3/Twobile.v168.RAR
http://www.ziddu.com/download/3396363/Twobile.v168.RAR.html
